#51 |
Don't doubt it!
Ok now someone do it!
http://firesignsynergy.spaces.live.com 348 whp 309 lbs wtq and just getting warmed up! 3.2 TII Acura Legend Twin Turbo, A force (induction) to be reckoned with
#52 |
I just need someone to sponsor me.
I figure about 6 grand should do it. lolHow about this idea. It might make things slightly simpler. I figure you might get a crank pulley made with an extra groove for a supercharger belt?
#53 |
Don't doubt it!
It's always an option for whoever steps up to the plate.
#54 | |
) lol. so about 3k you can get a really reasonable set-up that would last quite a while.Vortech and Paxton are both very reliable companies, and usually all you have to do is replace the turbine if one is messed up (cheap). I'm with you guys here I actually don't want to spend more than 1500 dollars..lol. Imma cheapass. Just saw a V5 Vortech CCW go for 550 brand new out of the box on Ebay. But didn't get it as I'll just wait for a V3. Edit: and I keep my AC ).
#55 |
Thanks
, I was at work so I didn't really have a lot of time and had to use an online photo editor, but I think it served the purpose...lol. Suggestions for Inlet, 90 degree turn to the right (same direction as outlet), and about 7 inches would allow clearance of the radiator by far.
#56 |
hmm my ideas would place the charger on the pass side to be able to run the piping to an intercooler the way I want as well as intake/filter.
#57 | |
#58 |
yep air to water.
I do like the cog belt with the tranfer over to a vbelt. I'm thinking incorporating something like that into the design will let you place the supercharger 2-3 inches further back than just a v-belt. downsiide is that it's not cheap.
#59 |
well if you could find a way of getting a GM 3800 V6 eaton supercharger mounted up (main problem would be air feed you'd need to put the TB some where far out connected i guess with a flexible hose they are dirt cheap although i'm very unsure if they'd be up to the task if you can roughly mounted it like ingenious pointed out by telion i guess your only other concern would to make a new pulley.
![]() ![]() ![]() Problem as you can see the inlet is at the back so you'd need to make a flange and mount a flexible hose (silicone?) run it to the front end (OE filter box location?) and make a bracket with the TB on that. you could also run two TB's if you'd like then with out much trouble. Al tough a inter cooler setup is a bit more difficult but i see away it could be done. Fabing up the custom intake manifold will be pricey. Last edited by Legend-Coupe; 09-20-2010 at 01:27 PM. |
#60 | ||
| KSPO.Kontroll. Coilovers!! or TEIN BASIC | Vipka9 | Non-OEM Parts | 1 | 03-25-2011 04:21 AM |
| ITB setup... What does it take??? | DriftKingOF541 | 2nd Gen. Legend Performance Enhancements | 5 | 03-13-2010 04:34 PM |
| G Bose Setup | 89HondaLegend | 1st Gen. Legend General Discussion | 3 | 12-03-2009 06:56 AM |
| Site for Cheapest Tein Basic Damper Kit | II KRUCKUS II | 1st Gen. RL General Discussion | 2 | 11-27-2009 07:11 PM |
| Anybody know basic physics? | Riboflavin | The Water Cooler | 13 | 09-26-2009 05:32 PM |
