when i purchased the car it had a switch under the steering wheel that connected to the rad fan.. The fan turns on by itself when it reaches above the normal temp and stays on but after a while if im at a stand still the temp gauge starts to climb and i have to hit the switch and it seems like the fan gets slightly louder as in a faster speed then the temp gauge goes to normal :dunno::dunno:
Might be hooked up to the condenser fan.
the fan that turns on when temp reaches above normal is the 1 right next to the batt and when i hit the switch that same fan still spins but faster and when i turn the a/c on both fans stay on
The fan control unit controls the two speed fans...I'm suspecting that is bad...
How to bypass radiator fan relays? | RobRiguez | 2nd Gen. Legend General Discussion | 24 | 03-13-2014 05:45 PM |
FS: Catalytic converter, Sun Visors, Fender Liner, Radiator Fans, Radiator | lady6spd | OEM Parts | 13 | 03-04-2010 10:03 PM |
I think my ac/heater fan may be going out.. | rrogers | 1st Gen. Legend General Discussion | 5 | 01-11-2010 10:23 PM |
radiator fan/condensor fan/horn relays | RobRiguez | OEM Parts | 5 | 09-02-2009 05:50 PM |
If you are a fan of The Shield... | sam o nela | The Water Cooler | 7 | 08-21-2009 01:05 AM |
