Old 12-06-2010, 08:24 PM   #1
Ablest31
Ablest31's Avatar
Ablest31 is on a distinguished road
Default Car smokes a lot now that it is cold
Now that's it is colder my car smokes a lot. It's coming out of the exhaust and it's seems to be way more than what I would consider to be normal. Just wondering if you guys have any clues as to what could be the issue?
Ablest31 is offline   Reply With Quote
Old 12-06-2010, 08:39 PM   #2
if it stops once at operating temp your okay.
Old 12-06-2010, 08:57 PM   #3
Type-M
Act up in the Ac'.
Type-M's Avatar
Type-M is on a distinguished road
Send a message via Yahoo to Type-M
I second this.
Type-M is offline   Reply With Quote
Old 12-06-2010, 09:14 PM   #4
Valve stem seals are the issue (most likely). It gets magnified when it's cold outside. Car takes longer to warm up. Check oil level and if you're ok then drive that muthafucka.
Old 12-06-2010, 10:57 PM   #5
Wayne-A-Ferd
The Slow Cruiser
Wayne-A-Ferd's Avatar
Real Name: Wayne
^ lol
mine smoke wether its cold or hot outside, but only if its sitting idleing for a bit, i know its the valves tho, i haven't seen anyone have any ring problem's without doing major mods but yeah, since its over 10 years old im gonna say its the valve seals :P
Old 12-06-2010, 11:05 PM   #6
DrDave
Just some guy
DrDave's Avatar
I was involved in the changing of guide seals this weekend. The biggest offenders are the intake guide seals. The oil goes down the intake valve stem and sits on the back of the valve. When you start it up the oil is washed into the cylinder and burns. While we did the swap with the heads off it should not be that tough to change the intake seals in the car. The intake valves are on the top of the valve-train. You would need a way to pry off the old seals. With the heads off we just grabbed the seals with some pliars and pulled them off. There is a nifty Acura tool for removing the seals.
I think in the next few years many more of our cars are going to be needing this service. If you are doing a timing belt anytime in the future that would be the time to do the guide seals.
Dave
DrDave is offline   Reply With Quote
Old 12-07-2010, 08:11 AM   #7
Ablest31
Ablest31's Avatar
I thought it was the valve seals as well
Old 12-07-2010, 10:25 AM   #8
^Didnt that get changed when you did your 3.5? How many miles is on the motor?
Old 12-07-2010, 02:06 PM   #9
Hmm my 'other car' has been doing a good bit of smoking out the quads here this week also. I had to change a t-stat this past weekend and even once the car has made it to operating temperature its doing it. I'm going to recheck my coolant level as it didn't accept much even with the breather valve open. Trust me guys Legend t-stats are MUCH simplier to replace!
Old 12-07-2010, 04:09 PM   #10
Ablest31
Ablest31's Avatar
Naw I think mike just put the motor in cause it only had low miles on it. I asked mike about it when I picked my car up last year cause it was smoking back then and he said it was from something leaking in my exhaust before the swap got done. So, I think I am going to have to get look into the valve stems.
car smokes a little ONLY when it's cold and the smoke smells like gas and idles rough Romero88 2nd Gen. Legend General Discussion 19 02-25-2013 12:13 AM
Car in the cold outside overnight...My Legend was upset! Icewind 2nd Gen. Legend General Discussion 17 12-18-2010 06:20 AM
Holy bat smokes... A milano convertible LegendaryT2 2nd Gen. Legend General Discussion 25 08-27-2010 03:32 PM
FS: LOT OF STUFF TO GO deleon22 OEM Parts 10 05-22-2010 08:16 PM
Car wont stay on during cold weather maxXspeed 2nd Gen. Legend General Discussion 5 01-26-2010 10:12 AM
