Old 09-03-2011, 07:14 AM   #1
Fred Clark
Fred Clark
Fred Clark's Avatar
Fred Clark is on a distinguished road
Default Replacing cylinder head side cover gaskets...a question
I am about to replace Cylinder Head Side Cover gaskets (o-rings) on front/left and back/right of motor.
Question: Do I need to use any type of gasket sealer (i.e., Permatex) when I
re-bolt the side covers. I see just a tiny bit of what look likes to be old gasket sealer of some kind between the cover and engine block, but I am not sure.
BTW, here is the breakdown on the costs of repair:
First went to the Acura dealer, for two Cylinder Gaskets (Part #: 12332-PH7-003), they wanted $51.48 ($25.74 each)
Then went to my import specialty parts store and bought a set of Beck-Arnley (Part #: BA036-1347) Valve Cover Gaskets for $12.95
They might even be cheaper online, but I don't use plastic.
CAUTION: At first, the parts store wanted t sell me a "universal" gasket set but upon close inspection and comparison with the OEM gaskets, the gaskets did not have the same "indents" at the bolt holes. These may leak.
Anyway, if you have done this recently, did you use a sealant of any kind?
If so, do I need to stay clear of silicone based products, etc.?
Thanks, as always!!
1987 Acura Legend L
2.5 L motor 4 door sedan
Odometer shows 215,000 miles (more like 225,000)speedo is broke.
Fred Clark is offline   Reply With Quote
Old 09-03-2011, 09:14 AM   #2
I used Hondabond to hold the gasket in place when putting the side covers back on. It's impossible to put it on without sealant since it'll just fall right off.
Old 09-03-2011, 12:05 PM   #3
stephen
I did the same thing but used blue RTV. Use just a little along the grove the o-ring fits in to hold it in place.
Old 09-03-2011, 12:53 PM   #4
Tippey
Pony
Tippey's Avatar
Real Name: Austin
Thats not true
its just the biggest pain in the ass
i managed to get it on in about a half hour. By that i mean the cover was on the ground and i kept trying to live it up without it falling off for a half hour lol.
Old 09-03-2011, 10:46 AM   #5
Ophidian
Ophidian's Avatar
Ophidian is on a distinguished road
HondaBond!
Tint, Eclipse AVN 6600, Clifford alarm, Stromung muffler, HO alternator, SRI, Fut front strut bar, aluminum crank pulley, custom floor mats, new shift boot, new paint, JDM headlights, JDM clear corners, JDM rear mudflaps, new valves (no ticks), new leather.
Ophidian is offline   Reply With Quote
Old 09-03-2011, 12:03 PM   #6
ochn77
ihate city officials
ochn77 will become famous soon enough
you need dental tools, carb cleaner and it helps to do the job w/ the motor out of the car, if you're not going to use any rtv or honda bond. and you still need those tools if you're going to expect a great seal even with rtv. but when i seal a rubber seal, the mating surfaces have been extremely tediously cleaned so the rubber gets a nice seal on the clean metal.
rtv'ing a rubber gasket is usually done when it's an old gasket and you're reusing it, or a couple of other situations like what James said, where you need it to stay in place while you torque it. in that case sometimes you can actually just put only a few spots of the hondabond so it hold it, but you're still getting just a rubber seal.
orings can use rtv when reusing them as well, but in general, i've found that a very clean and brightly shined with carb cleaner metal surface is best when it comes to rubber gaskets.... and mainly only for this reason. if you use Hondabond or rtv, yes you well get a good seal, but you can't take the part off on a regular basis without completely recleaning the mating surfaces.
trust me, i've never had a seal leak that i've done. rtv's great, but i typically leave it off brand spankin new rubber gaskets and orings because they do great without it too.
ochn77 is offline   Reply With Quote
Old 09-07-2011, 06:15 AM   #7
Fred Clark
Fred Clark
Fred Clark's Avatar
You are not serious about taking the motor out fo the car; I mean you are stating this tongue in cheek, right?
Dental tools? A fine sense of wit but totally disconcerting......
1987 Acura Legend L
Old 09-07-2011, 09:06 AM   #8
stephen
I'm sure he's joking.
It isn't really a big deal to replace those gaskets. I would use a little RTV
(the blue kind is OK) to hold the gaskets in place. Then just put them back in and reinstall the bolts. Don't overtighten the bolts ( ~10 ft-lbs or less). Notice there are arrows indicating the up direction. Also clean all the oil off the gasket surfaces with something like lacquer thinner or brake clean. That's about it.
Old 09-03-2011, 01:01 PM   #9
Yes.
But it is also commonly recommended that you put sealant anywhere there is a corner or bend when doing gaskets on pretty much any car....
Old 09-03-2011, 01:49 PM   #10
Tippey
Pony
Tippey's Avatar
Real Name: Austin
The gasket i had was not formed for the shape
It was round and in the shape of a circle
i had to push it into all of the little hold down things and then mate it up quickly before it fell apart. I finally got it and i felt accomplished.
6 speed flywheel cover and slave cylinder cover Jonslegend OEM Parts 3 04-11-2011 08:04 AM
valve/side cover gaskets 87silverbullet 1st Gen. Legend General Discussion 10 03-26-2011 04:44 AM
93 legend Sedan Cylinder head Drivers side!!! $$ sicclegend OEM Parts 4 11-30-2009 02:02 AM
flywheel dust cover slave cylinder cover MasTeR.LeGenD OEM Parts 0 11-01-2009 03:43 PM
Side Cover Valve Gaskets? Jaysus! 1st Gen. Legend General Discussion 11 10-26-2009 06:56 PM
