Go Back   AcuraLegend.Org - The Acura Legend Forum for All Generations of the Honda / Acura Legend; 1986 to Present > Marketplace > "Not Mine"
Old 10-13-2011, 08:20 PM   #1
95legendcp
95legendcp is on a distinguished road
Default 6spd manual transmission - $550 (okc metro)
http://oklahomacity.craigslist.org/pts/2647100424.html
1995 Acura Legend LS Coupe 6spd. JDM TYPE II, 6spd trans (lower mileage). 5-spd flywheel, EXEDY clutch. Fut MLS strut bar, H&R springs,Monroe shocks,ADDCO Front & Rear sway bars, FUT Tie Bars,SPC ball joints, MOOG Front Upper control arm anchor bolts, EBC ULTIMAX Rotors f+r,AKEBONO ceramic pads f+r. Poly mounts(60a). BLACKEND damper.18x8 40 offset KONIG Verdict. BF GOODRICH G-Force T/A KDW.
95legendcp is offline
Old 10-13-2011, 08:41 PM   #2
Nice find there Wes!
94LegendaryAcuraGS is offline
Old 10-13-2011, 09:48 PM   #3
dooley
Virginian
dooley's Avatar
Real Name: Dan
dooley is on a distinguished road
hgeez: wish it was closer
dooley is offline
Old 10-14-2011, 08:01 AM   #4
Dylan
Real Name: Dylan
Dylan is on a distinguished road
Hmmm.... I will be in Wichita this weekend. Does the 6spd just drop in as direct replacement to the 5spd or are there modifications and parts that need to be bought?
Dylan is offline
Old 10-14-2011, 08:31 AM   #5
95legendcp
Same fitment. Should bolt right up.
Old 10-14-2011, 09:04 AM   #6
If I'm mistaken I don't think they offered a 6sp in the 93 model ?? OP says it came out of a 93 and it also looks like a single mass flywheel hence 5sp ??
bsmooth1027 is offline
Old 10-14-2011, 09:19 AM   #7
93had six speeds coupe only
GreekPower is offline
Old 10-14-2011, 09:40 AM   #8
Dylan
Real Name: Dylan
Is there a way to tell? Definitely don't want to buy it if it's a 5spd, I've got one of those
Dylan is offline
Old 10-14-2011, 09:41 AM   #9
The plugs. If it has 2 plugs verses 3. 3 electrical plugs = 6speed
Old 10-14-2011, 09:41 AM   #10
I'm just saying cause my 93 sedan is 5sp and the flywheel looks to be a 5sp am I correct ?
FS: Manual transmission and manual differential The Crowing OEM Parts 7 01-16-2012 05:43 PM
6spd Manual Tranny question LA Legend 2nd Gen. Legend General Discussion 5 02-01-2011 12:02 PM
91-95 manual flywheel 5spd or 6spd JX2004 Non-OEM Parts 0 01-15-2011 04:33 PM
10W30 for 6spd manual tranny. Good enough? LV_legend_2 2nd Gen. Legend General Discussion 6 12-04-2009 06:16 AM
