Old 12-20-2013, 06:20 PM   #1
scheibler
scheibler's Avatar
scheibler is on a distinguished road
Default Humming noise when m/t is in reverse?
This happens mostly on cold starts when I first start the car to leave. The car makes a humming noise kinda like the fuel pump priming, but way louder and longer. Sounds like it's coming from the drivers side from the rear, but not positive. Diff and tranny fluid has been replaced. Tranny with penzoil synchromesh and diff with regular Mobil 1 gear oil. It's really cold here if that matters. I used to also not be able to shift into reverse sometimes without rolling it forward or backwards, but that problem, which I've read is common, hasn't been a problem in over a year....now it humms
Ideas?
scheibler is offline   Reply With Quote
Likely cause of 5MT not staying reverse? wadd3456 2nd Gen. Legend General Discussion 22 07-18-2014 03:26 AM
Loud humming noise killaswa6 2nd Gen. Legend General Discussion 11 01-16-2014 10:16 AM
Problems going reverse White Rider 92 2nd Gen. Legend General Discussion 11 07-15-2013 04:54 PM
grinding in reverse dbn 2nd Gen. Legend General Discussion 7 05-14-2011 02:18 PM
No reverse or 3/4th gear Tippey 1st Gen. Legend General Discussion 4 12-26-2010 02:42 PM
