Old 01-27-2016, 03:44 PM   #1
tjmelena
tjmelena is on a distinguished road
Default Noob and the Snowball's CD changer
OK folks, on our 1000 mile trip to the Snowbelt from Legendland I was enjoying afew CDs. I won't offend you with an old fart's music choices, but midway back (Virginia/West Virginia) the CDs started skipping.
So I thought I'd ask the electronically inclined for a little help;
1) Call me stupid (or cautious) but rather than break the changer, can somebody give me a "quiki wiki" on how to pull the CD changer?
2) Once its out, how does the case open?
3) Any ideas what might be wrong......... component cleaning maybe???
4) If I gotta use a soldering gun to fix it, I'll let you guys know what hospital to send flowers to while I recover from my self-inflicted burns
Looking forward to your to your thoughts
tjmelena is offline   Reply With Quote
Old 01-27-2016, 05:22 PM   #2
Captain Slow
Ken
Captain Slow's Avatar
Captain Slow is a jewel in the roughCaptain Slow is a jewel in the roughCaptain Slow is a jewel in the rough
The changer is pretty easy to take out. There are four bolts at the base of the unit in the four corners and a single cable to disconnect. You peal the carpeting in that area back to gain easy access to the bolts.
The changer has a mechanism that you switch to reflect the mounting orientation. If that is in the correct position, it must be a problem with the inner workings. I've never taken a changer apart but a CD reader is pretty simple. It's a lens on a track that moves back and forth. Something must either be loose or worn out.
It's an adventure! Just organize the screws you take out and move slowly. When reassembling, don't over-tighten any screws that thread into plastic. Also, if you're a dummy and strip a screw head, you can take a file to a couple sides of the screw head and use a wrench on it.
It's worth mentioning, there are three different CD changers that plug into the legend. The stock alpine that only plays pressed CDs, an aftermarket alpine that can play burned CDs, and an aftermarket alpine that can play burned MP3 CDs. If things don't work out with your repair, an upgrade might be in order.
Old 01-27-2016, 05:31 PM   #3
tjmelena
thanks Captain, You're a gentleman and a scholar. But that's coming from a lawyer so take it for what it's worth.
Tim
Old 02-01-2016, 11:56 AM   #4
tjmelena
By the way......
What are the 2 replacement disc changers?
Old 02-01-2016, 12:07 PM   #5
Captain Slow
Ken
CHM-S630 - plays burnt CDs - Plug and play - m-bus plug (this is what the legend is pre-wired with)
CHA-S634 - plays burnt+MP3 CDs - requires ai-net to m-bus adapter
They seem to be getting harder to find and there may be other more modern solutions available with a different adapter. You could post a WTB on the forum, though, or scan through ebay. It looks like they sell for $50-100.
Old 02-01-2016, 04:12 PM   #6
I learned something new today! That is why there are a couple different cd changers and I suppose the ones that are "Alpine" in cosmetic appearance! Good to know this Ken!
Old 02-02-2016, 11:35 PM   #7
tjmelena
Thanks Ken
Old 02-07-2016, 08:57 AM   #8
tjmelena
Ken,
Do you know if CD cartridge from OEM can be used with either CHM-S630 or CHA-S634?
Old 02-07-2016, 09:39 AM   #9
Captain Slow
Ken
I never owned the OEM unit so I'm not sure. I know the magazines are interchangeable between the two units I mentioned. Hopefully someone else can chime in.
Old 02-07-2016, 11:46 AM   #10
4HondaOwner
Sedan Coming Soon
4HondaOwner's Avatar
Real Name: Kevin Amoth
So many numbers.
I have an Alpine CHM-S650RF that is my tried and trusty CD changer backup for both of my cars. Sure it is not OEM, but when I just drop it in the bucket in the trunk and hook it up, it never complains or skips tracks.
Mine was made in June 1995 and has treated me well over the years.
Good luck Tim.
7-1-25 *1994 GS Automatic Sedan 99,925 miles* June 2025 miles driven = 20 (not by me!)
Noob needs help Block 1st Gen. Legend General Discussion 9 08-01-2013 09:02 PM
noob in NM lizzi New Member Introductions 7 05-29-2013 04:38 PM
FS: BlitzSafe iPod/CD Changer Adapter setup w/Alpine CHA-S634 Changer stevieray Non-OEM Parts 14 04-22-2012 08:40 AM
another noob bigluelok New Member Introductions 11 06-17-2009 08:16 AM
Noob here daveCFPrez New Member Introductions 10 06-03-2009 08:03 PM
