Old 11-05-2020, 07:20 PM   #1
mifaalc
mifaalc is on a distinguished road
Default '93 Legend Coupe Not Warming Up
My '93 Legend Coupe takes a long time to warm up, like maybe 10 mins before the temp needle moves away from C. After warm, then I take it on the open road (ie,freeway) and then the needle drops to COLD, anybody else experience this situation?
mifaalc is offline   Reply With Quote
Old 11-06-2020, 04:30 AM   #2
replace the faulty thermostat, most likely your t-stat is stuck open, which actually usally means the rubber btwn the 2 portions is worn out and lets coolant flow thru. our suggestion would be to use a OEM acura t-stat, theyre inexpensive. you can order one from acura of augusta in GA
also since youre in florida, check out the meets section for our upcoming meet
Old 11-06-2020, 05:11 AM   #3
mifaalc
Default FL Meet-UP
My Legend is actually in the shop today, thanks for that awesome info. Looks like the next meet-up is Jan 2 in Floral City right?? Thanks again!
Old 11-06-2020, 10:46 AM   #4
yessir and if you ever need it, i'm in south sarasota. we do work on alot of legends
Old 11-06-2020, 02:34 PM   #5
Default Could also be a bad temp sensor
It could also be a bad sensor misinforming the temp gauge:
http://forums.acuralegend.org/showthread.php?t=26951
Old 01-01-2021, 02:53 PM   #6
mifaalc
Is the meet-up at Pudgees still on schedule for Sat Jan 2, '21 @ 1:00??
Can Legend Sedan Sub-Frame part work for Legend Coupe? kalena 2nd Gen. Legend General Discussion 1 10-18-2020 09:08 AM
WTT: Trade coupe for sedan: 1995 Legend LS Coupe, pearl white, auto frantinez63 Legend 7 12-21-2011 12:40 PM
FS: 1993 Acura Legend Coupe (Memphlow's Coupe) Memphlow Legend 28 08-14-2011 01:54 PM
87 legend 2.5 idling bad after warming up. hayesmph 1st Gen. Legend General Discussion 10 06-12-2011 08:45 AM
Climategate: Stolen emails implicate possible coverup by the global warming industry kotetu The Water Cooler 9 11-25-2009 03:27 PM
