Old 12-23-2022, 09:52 AM   #1
Cool Tons of Legend Coupe and Sedan Parts
Since I?m banned from Facebook? might aswell list some items here. Hopefully the limits will allow me to post the full list.
But all parts fit 1991-1995 acura legend coupe and sedans. If you don?t know just ask. That said. My cell phone is in my signature, feel free to text if you don?t see a part listed, cause 95% chance I have it. All items start at $10 plus shipping.
Type F = Tan
Type A = Black
Coupe = 2 Door Legends
Sedan = 4 Door Legends
OEM FACTORY Big Blue Tote
Type F Coupe Floor Mats Set
Type F Sedan Floor Mats Set
Type F Sedan Rear Floor Mats
Type F (91/92) Driver Floor Mat
Type A Front Floor Mats
Type A Sedan Floor Mats Set
Type A Sedan Rear Headrest
Brown Steering Wheel Airbag
Brown Dash Airbag
Mint Cupholder
Broken, but working cupholder (needs lock)
Type A Armrest (Mint)
Type F Armrest (needs recovered)
Type A Armrest (needs recovered)
Type A Sedan Rear Seat Pass thru
Type A Sedan Bose Door Speaker Covers (2 pair)
Type A Sedan Door Speaker Covers
Type A Sedan Driver Door Speaker Cover
Type F Sedan Bose Driver Door Speaker Cover
5 Speed Shifter Boot (7/10)
Type A Dash Airbag Cover Only
Type F Coupe Vanity Visors (2 sets)
Type F Coupe Mini Visor (2)
Type F Sedan Mini Visor
Type A Sedan Driver Side Visor
Type A Coupe Rear Deck Speaker Grills (both styles)
Brown Driver Side Door handle (Cracked, Peeling)
Brown Driver Side Door handle (Cracked)
Brown Driver Side Door handle (Mint)
Memory Seat Buttons (2 pieces)
Type E Heated Seat Buttons
Black Passenger Side Door Handle (Mint)
Type A Coupe Door Fuzz/seal Mint (3 sets)
Front Sunroof Drain (6)
Rear Sunroof Drain (2)
ENGINE Big Blue Tote
Type F Coupe Sunroof Fuzz Trim (2)
Type 1 Auto Gauge Cluster (parts)
94/95 Gauge Cluster trim (with buttons)
Type F Ebrake handle (good for modding)
Main Engine Fuse Block
Main Engine Fuse Block (busted corner)
L Model Climate Control
Sedan Rear View Mirror
Type A Under Glovebox Trim (2)
Dash Duct Work (2 pieces)
Front Door Speaker Mounts (pair) coupe I think
91-92 Black Steering Wheel Trim
91-92 Brown Steering Wheel Trim
94/95 Black Steering Wheel Trim
94/95 Tilt Steering Wheel Buttons (3)
92 L Auto ICU (May fit others) 38600-SP0-A011-M1 Lot NO. 1z10
6x9 to 6.5? Rear Speaker Conversion Bracket (set)
CD changer Mounting Bracket
Type A Rear Deck Tweeters
Automatic Gear Selector w/ Trim
Base Black Opening Ashtray For Console
OEM Door Tweeter
Hazard/Clock Buttons
Automatic Dead Pedal (2)
94/95 Sedan Grill (2)
91-93 Sedan Grill
Beauty Trim 71122-SP1-0000 (should be sedan)(2)
Coupe Grill (2 bezels red & white)
Coupe Rear Speaker Mounts
Type F Coupe Hard Lower Plastic Door Trim (Set)
Type F Coupe A Pillar (2 sets)
Type F Coupe B Pillar (Driver)
Type F Coupe
Type A Sedan Hard Lower Plastic Door Trim (Front set/Driver rear)
Wiper Motor Assembly
Sedan Window Motor and Regulator (Front Left)
Sedan Window Motor and Regulator (Front Right)
Sedan Window Motor and Regulator (Rear Right)
CD Changer Metal Mount Bracket
CD Changer Pocket
Type A Sedan Rear Deck Speaker Mounts
Sedan Rear Left Window Motor
Sedan Rear Right Window Motor
Alpine CD Changer with case Model CHM-S601
Type F Front Carpet Pieces with Bent Plastic (Set)
Type F Front Carpet Pieces with Black Carpet
Type F Passenger Carpet Piece
Type A Passenger Carpet Piece (2)
Type A Driver Carpet Piece
Chrome Door Strikers (set of 2)
Sedan Trunk Carpet Taillight Covers (2 Sets)
Coupe Trunk Carpet Taillight Covers (Set)
Type F Inner Glove Box Trim (3 Pieces)
Type F Emergency Brake
Type F Gas Door Handle with Cover
Type F Coupe Rear Roof Light
Type F Hood Release
Type F Console Carpet
Type F Seat Bolt Covers (Coupe, missing 1 pass rear)
TYPE F PARTS Black Bottom Tote
91-93 Type F Under Dash Panel (Driver)
94/95 Type F Under Dash Panel (Driver)
94/95 Type F Radio Trim
94/95 Type F Under Dash Trim Panel (Passenger)
94-95 Type F Glovebox
Type F Coupe A pillar Handle (3)
Type F ?oh shit? handle (3D 6P)
Type F Center Console Rear Plastic (4)
Type F Rear View Mirror Cover
Type A Center Console Rear Plastic
Type A Emergency Brake Trim
Headlight Bulb Cover
Type F Coupe Door Fuzz/seal set (Mint) (2 Sets)
Type F Rear Overhead Light (2)
Type F Coupe Doom Light (2 Complete, 1 Parts)
Type F Trunk Button
Type F Front Seat Map Pocket
Type F Sedan B Pillar Seatbelt Slider
Type F ?oh shit? Covers (2)
Type F Coupe B Pillar Passenger Side
Type F Coupe Sunroof Fuzz Seal Mint
Black tote 2
Chipped Ecu (3.5/auto) 37820-PX9-A67 AAS
Auto Ecu 37820-PX9-A67 AAS
Manual Ecu 37820-PY3-A02 YAM
Manual Ecu 37820-PX9-A04 AML
94 LS COUPE IN A BOX Black Middle Tote
94/95 LS Auto coupe entire cabin harness with all control boxes all clips, no cut wires.
Part numbers:
32155-SP1-A132 (harness for front by visors)
38910-SP0-A01 (under dash box, relay assy strg column)
39880-SP0-A110-M1 (under dash box,unit assy security)
SP0 D/L (mistuba door lock control) RK-o264)
36700-SP0-A51 (pass under glovebox, auto cruise control unit)
39900-SP0-A01 (behind rear seat, silver box)
ABS6A-SP0-A(KA) (abs ecu brain)
SPO LH (under dash box, Mitsuba inter lock control, RK-0208)
Fuse box
ICU 38600-SP0-A112-M1
4D20 (behind rear seat D/S small control box)
38900-SP0-A11 (behind rear seat D/S unit assy ETS)
Cabin Harness D/S: 32157-SP1-A252
Sunroof Harness: 70316-SP1-A003
Cabin Harness P/S: 1L2 R32107SP1-L282 (1L2R2G30285)
Cabin Harness P/S: 1L2 A32107SP1-L282 (1L2A2G30274)
Cabin Harness Behind HVAC: 1L2 F32107SP1-L282 (1L2F2G30275)
Bose Amp (tested)
ABS6A-SP0-A(KA) (abs ecu brain, GS)
38900-SP0-A11 (unit assy ETS, GS)
Driver Side Soft Closer
Passenger Side Soft Closer(Brand New)
Automatic Transmission Harness (dildo style)
SRS Computer (under armrest)
KeyLess Entry with Harness (08E65-SP0-2011)
77961-SP0-L910 (SRS Harness)
77920-SP0-N810-M1 (Floor Airbag Sensors Driver/Passenger)
Coupe Rear Deck Hole Covers (Set)
Type F Coupe Seat Belts with latches(Front/Rear)
Grey Tote 1
OEM Sedan Tail lights (Set)
OEM Sedan Clear Tail lights (Set)
OEM Coupe Tail lights (Set)
OEM Sedan Headlight (Driver)
OEM Coupe Headlight (Driver, One Broken Lower Inner Tab)
OEM Coupe Corner Light (Driver, Busted Lens)
OEM Coupe Corner Light (Passenger)
OEM Sedan Corner Light (Passenger, Busted Lens)
JDM Headlight Housing (Driver, No Lens/Shroud)
JDM Headlight Shroud (Passenger, Black)
JDM Driver Fog Housing (2)
JDM Passenger Fog Housing
JDM Headlight Glass (Driver)
JDM Fog Cover with Plug
Sedan Tail light Gaskets (3 sets)
MORE ENGINE Black Bottom Tote
RL Fuel Rails with FPR
Type 2 Fuel Rails with FPR
Legend Cruise Control Box w/cable
Crossover Coolant Pipe (2)
RL Alternator Bracket
Legend Alternator Bracket
91/92 Legend Engine Mount (Passenger)
RL TCS with Bracket
Legend TCS
Legend Fuel Injectors (3) Type 2
Legend VIS Valves and Piping
RL Throttle Body TPS Up
Legend Throttle Body TPS Up
Legend Coil Pack (7)
91-92 Front Engine Mounts (Set)
Legend Map Sensor Box
Legend Manual Clutch Line w/ Dampener
OEM o2 Sensor
Legend Coolant Overflow Container
Legend Cam Gears (Set)
Legend Thermostat Housing
Legend Front Shock Forks
Legend Extension Shaft (Thru Oil Pan)
Legend Upper Alternator Bracket (2)
Legend EGR Tube (Clean)
Legend EGR Tube (Welded shut)
Legend OEM Fuel Pump w/ Filter (3)
Legend IACV (3 Modded,1 OEM)
Legend Windshield Washer Pump (2)
Legend Cam Position Sensor (2)
Windshield Washer Container Top (2)
Oil Cap (2)
Pulley (2)
Legend Charcoal Canister
Legend Head Bolts (12)
Rear Transmission Bracket
Pulley Adjuster
Legend Horn (2)
Legend Head Coolant Fitting
Radiator Cap (2)
Legend Engine Harness Relay Bottoms (2 Sets)
Fuel Pump Tank Seal (2)
Legend Cam Back (Driver Side)
Legend Cam Covers (1 Driver, 2 Passenger)
Legend Vacuum Cylinder
Radiator Mounts (2 Driver, 1 Passenger)
Legend FPR (Type 2)
Coolant Overflow Cap
Legend Hood Release Cable
Legend Throttle Cable
Legend Knock Sensors (3)
Legend Oil Pressure Sensor
Legend Air Intake Temperature Sensor
Check Valve (Brake Booster)
Power Steering Bracket
Legend Clutch Slave Cylinder Plunger
Coolant Bleeder Valve
Radiator Drain Peacock
AC Condenser Mounts (3)
Subframe Rubber Mounts (7)
Aluminum Lightweight Pulley (Alternator)
Sedan Gas Door
Automatic Transmission Upper Mount
Igniter Box
RL mini BBK Brackets
Type 1 PowderCoated Caliper Brackets (Front)
Coupe Rear Window Black Fuzzy Seal (set)
Coupe Hood (2)
Coupe Front Fenders (2 sets)
Coupe Driver Side Door
Coupe Door Glass
91-93 Coupe Front Bumper
94-95 Coupe Front Bumper
Coupe Side Molding (Cashmere)
Type F Coupe Front Seat (Driver)
Sedan Rear Bumper (2)
94-95 Sedan Front Bumper
Sedan Front Fenders (2 sets)
Sedan Trunk
Sedan Hood
JDM Type A Armrest
JDM Burlwood Console (2)
94-95 Sedan Fog Light Covers
94-95 OEM Fog Lights
94-95 OEM Sedan Fog Light Kit (shrouds/brackets/Fogs)
91-93 OEM Fog Lights
Sedan Smoked/Tinted Headlight Covers
93-95 Air Intake Tube w/ Box
ABS Pump (3 working, 2 need Rebuilt)
Type 2 Intake Manifold
Type 2 Muffler
Type 2 Cams
Type 2 Heads (Checked)
3.5 Bare Block
3.2 Bare Block
3.5 Motor (For Parts Only)
3.2 Motor (For Parts Only)
Type F Coupe Front Door Panels
Type A Coupe Rear Panels
Coupe Sunroof Assembly (2)
Coupe Headliner (5)
Coupe Burlwood Window Switches (2 Sets
Coupe Carbon Fiber Window Switches
Sedan Burlwood Window Switches (Complete Set)
Automatic Burlwood Center Console (6)
Manual Fake Wood Center Console (2)
Sedan Sunroof Glass
Sedan Door Glass (Full Set)
OEM Shocks and Springs (Used, 42k)
Aftermarket Parts
Hella Horns (Red)
Greddy Exhaust (2.5? piping)
Lightweight Aluminum Crank Pulley
Lightweight Aluminum Accessory Pulleys
OBX Headers with Cat Delete
NBIB Denso o2 Sensors (Longer)
Ported and Polished Type 2 Intake Manifold
Ported and Polished Type 2 Heads
WebCams Hardweld Race Cams
Stage 5 Manual Chipped ECU
Radiator Fans (Kit)
All Metal Radiator (Used)
GreekPower is offline
Old 01-02-2023, 06:50 AM   #2
Daddykay24
Daddykay24's Avatar
Daddykay24 is on a distinguished road
Now how did you manage to get kicked off face book. I do recall you taking ban vacation or two from here as well. Looking for a sedan hood insulation. I have Alan hunting one for me also.
http://i18.photobucket.com/albums/b114/daddykay24/tristate-1.jpg
Tri-state 09
Daddykay24 is offline
Old 01-06-2023, 03:07 PM   #3
I post things that a liberal cries about at night.. like there’s 2 genders haha.
That’s how fb bans you for 24 hours up to 90 days.
I do not have that tho.. I honestly rip those out I hate dealing with them lol
Old 01-07-2023, 04:49 AM   #4
Default Fire blanket
Back in 1990 my wife & I were helping my parents shop for a new car. An Acura salesman was showing us a 1990 Legend (which my parents ultimately bought). When he opened the hood, my wife & I pointed at the hood insulation and laughed that it had the "special engine fire blanket, also". The salesman looked quite puzzled, until we explained that we had just come from the Nissan dealership where one of the lot vultures had claimed that the plastic tabs which hold the underhood insulation were designed to melt quickly if there was an engine fire in order to drop the fire proof blanket unto the engine to smother the fire. The Acura salesman rolled his eyes and said "we don't brag about our engines catching on fire."
JKLedbetter is offline
Old 01-09-2023, 04:18 PM   #5
Yeah those are REALLY hard to find if at all. Rumor has it that Acura was looking for one when they "rebuild" Chris Bridges (a.k.a. Ludacris) Legend after his accident which they showed at SEMA a few years back. Had I known how difficult it would be I would definitely have picked up the one I had ordered from the local dealership when I did my build in 2013. I ended up finding a semi decent one at the yard and carefully got it off. I think one of those plastic tabs took a "leave of absence" though.
As for Lou getting banned . . . he's a pro at that kind of stuff nowadays.
Sounds like the back and forth I've seen from the Nissan and Acura dealerships in the past. Fun times especially when my Legend wrenchman was working at the Nissan dealership. Now I have no regular Legend wrenchman other than what I can get done.
94LegendaryAcuraGS is offline
FS: 91-95 parts coupe and sedan tito1228 OEM Parts 3 10-05-2015 02:55 PM
Someone smashed my legend :( Are these coupe/sedan parts interchangeable? scheibler 2nd Gen. Legend General Discussion 23 01-22-2014 08:46 AM
FS: G2 Parts Sedan/Coupe tito1228 OEM Parts 20 12-16-2013 05:41 PM
FS: 1st Gen Legend Parts KA 1 - 6 Coupe Sedan JDM / EDM 3GCVC OEM Parts 27 10-07-2012 08:03 PM
Parting Out: '91 Legend L Black/Tan Auto. Tons of parts LegendLand Parting Out 52 01-14-2011 03:46 AM
