Old 03-29-2025, 06:18 AM   #1
janez legend
janez legend is on a distinguished road
Default Engine Crankshaft Position Sensor
I own a Legend Coupe, year 1992. I need a camshaft sensor, part number: 37840-PY3-016. I can't find it anywhere to buy. It only exists with part number: 37840-PY3-026. Can anyone help me if it is suitable for my car?
janez legend is offline   Reply With Quote
Old 03-30-2025, 01:14 PM   #2
You might try Amayama.com:
https://www.amayama.com/en/part/honda/37840py3026
or eBay:
https://www.ebay.com/itm/135120705625
Old 04-08-2025, 10:55 PM   #3
janez legend
It's not exactly the same catalog number. Is it compatible?
Old 04-09-2025, 09:54 AM   #4
the reason why 91/92 is different than 93-95 legend and 96-04 RL is the plug. instead of a male plug its a female plug. its the same sensor BUT the plug is reversed. I probably have a used 91/92 laying around if u want it
Old 04-09-2025, 10:05 AM   #5
95legendcp
95legendcp is on a distinguished road
Greek is right about the plugs being reversed.
You can purchase aftermarket on rock auto. Its listed there as a crankshaft position sensor. Its located under the Ignition column.
https://www.rockauto.com/en/moreinfo...=7196&jsn=1830
Here's one on ebay.
https://www.ebay.com/itm/176373652696
1995 Acura Legend LS Coupe 6spd. JDM TYPE II, 6spd trans (lower mileage). 5-spd flywheel, EXEDY clutch. Fut MLS strut bar, H&R springs,Monroe shocks,ADDCO Front & Rear sway bars, FUT Tie Bars,SPC ball joints, MOOG Front Upper control arm anchor bolts, EBC ULTIMAX Rotors f+r,AKEBONO ceramic pads f+r. Poly mounts(60a). BLACKEND damper.18x8 40 offset KONIG Verdict. BF GOODRICH G-Force T/A KDW.
95legendcp is offline   Reply With Quote
Old 04-10-2025, 07:50 AM   #6
Yes most of the electrical system changes from the 1991 - 1993 verses 1994 - 1995 Legends were reversals of the plugs. I can only imagine that the car was more popular than anticipated and the 85 million initial order of the plug stock was low so they made a new order. Why they went male for female and female for male plug reversals still baffles me.
legend coupe 92
WTB: Camshaft position sensor for 2.7l g1 samo8ty5 OEM Parts 0 02-08-2025 10:08 AM
throttle position sensor legend91 1st Gen. RL General Discussion 2 06-04-2015 09:34 AM
WTB: G2 Cam Position Sensor 89HondaLegend OEM Parts 1 10-08-2013 04:33 AM
91-92 cam position sensor minhja OEM Parts 2 09-12-2012 08:35 AM
Crank Position Sensor MistaBigXXL 2nd Gen. Legend General Discussion 2 07-22-2009 08:06 AM
