#11 |
U Sure? you need to learn to do this yourself...they have you cornered...the next step if it isn't air is to replace the master or slave cylinders and THEY WANT YOUR MONEY...HONESTLY OR NOT IF THEY THINK YOURE AN 'EASY MARK' LIKE A LITTLE OLD LADY
possibly..... |
#12 | |
![]() Quote:
Like I said before I'm on assignment away from home with no garage or tools...this was the nearest shop that looked like it MIGHT be reputable.
1988 Legend LS Sedan Stock Everything (except stereo). |
#13 |
I may have figured this out, the last time the car got hot from city traffic I tried different clutch pedal positions and it disengages fine as long as you don't put the pedal on the floor (I'm a big guy, so I always tended to use pedal max throw). Feels like the throw-out bearing is pushing the disc onto the flywheel?
Clutch works with no issues as long as I leave a little room at the bottom. I'll see if I can adjust the pedal a bit. Or maybe the aftermarket parts don't have the same clearance between disc and throw-out bearing? The shop claimed they couldn't duplicate it and I thought they were BS-ing me, but thinking back on it the mech was about 5'2'...
How hot is it where you are??!?! | Aking | The Water Cooler | 47 | 07-21-2011 09:35 PM |
Removing Clutch/Swap to 5-Speed Clutch | brettallen59 | 2nd Gen. Legend General Discussion | 1 | 01-10-2011 08:55 AM |
How hot does...... | XxWEISERxX | 2nd Gen. Legend General Discussion | 17 | 07-07-2010 07:19 PM |
Fired for being Hot? | cakes | The Water Cooler | 47 | 06-11-2010 06:07 AM |
This is one hot G1.... | IGotALemon | The Water Cooler | 15 | 08-29-2009 09:55 AM |
