Old 11-26-2010, 05:30 PM   #1
985LegendCoupe
985LegendCoupe's Avatar
985LegendCoupe is on a distinguished road
Default radiator fan
i dont know why my radiator fan wont stop when i turn the key off. i just came back from frriends house which is 15 minutes away and its 40 degrees outside, so i know my car is not even hot enough. not im home and the fan is not stopping, help.
985LegendCoupe is offline   Reply With Quote
Old 11-26-2010, 05:51 PM   #2
985LegendCoupe
hello? any help?
Old 11-26-2010, 05:52 PM   #3
-X-
GS MAXXX
-X-'s Avatar
Send a message via AIM to -X-
The fans usually stay on for a bit even after you turn the key off especially if you've had the heat on. Does it take longer than 5 minutes?
Old 11-26-2010, 06:42 PM   #4
985LegendCoupe
yes, still on after 40 minutes now. i will pull the fuse and check it in the morning so it wont kill the battery.
Old 11-26-2010, 06:52 PM   #5
BklynSoulja
BklynSoulja's Avatar
BklynSoulja is on a distinguished road
it most likely a faulty fuse/relay
<a href=http://imageshack.us/photo/my-images/836/sigqzb.jpg/ target=_blank><a href=http://img836.imageshack.us/img836/5751/sigqzb.jpg target=_blank>http://img836.imageshack.us/img836/5751/sigqzb.jpg</a></a>
BklynSoulja is offline   Reply With Quote
Old 11-26-2010, 06:53 PM   #6
Geneva_Jee
Gold Member
Geneva_Jee's Avatar
if not the fuse/relay, then it might be the fcu [fan control unit]
Old 11-26-2010, 06:56 PM   #7
985LegendCoupe
what will fix that?
Old 11-26-2010, 07:00 PM   #8
BklynSoulja
a replacement would fix that
Old 11-26-2010, 07:00 PM   #9
Geneva_Jee
Gold Member
Geneva_Jee's Avatar
a replacement.
Old 11-26-2010, 07:11 PM   #10
985LegendCoupe
i just checked, its still on, one thing or another. now both the coupe and the sedan are down.
How to bypass radiator fan relays? RobRiguez 2nd Gen. Legend General Discussion 24 03-13-2014 05:45 PM
Radiator fan noise Romero88 2nd Gen. Legend General Discussion 3 08-15-2010 12:16 AM
radiator fan 904DR 1st Gen. Legend General Discussion 3 06-10-2010 05:34 PM
FS: Catalytic converter, Sun Visors, Fender Liner, Radiator Fans, Radiator lady6spd OEM Parts 13 03-04-2010 10:03 PM
radiator fan/condensor fan/horn relays RobRiguez OEM Parts 5 09-02-2009 05:50 PM
