i am looking to swap type 1 front calipers for some type 2 and what i want to know is do i need the type 2 bracket or can i use m type 1 bracket?
you can use your type I bracket but won't be able to use the type II rotor.
the type II rotor is thicker.
#5 |
i would get the bracket and a rotor. that way you can take advantage of typeII rotors, they work better then type1 rotors, unless ur's are new, then i'd use em until they warp and then upgrade to the typeII calipers.
btw, i know we can carry typeII rotors for about $200 for a whole set, and there is a $50 core charge per caliper.
94 KA8 DMM LS 6spd "MISTY" 2017-present 94 KA8 Milano LS 6spd "Milano" 2012-2017 RIP stupid camry94 KA8 SGM LS 6spd "Annie" 2008-???*top secret* ![]() 94 KA7 DMM GS auto "Misty" 2008 RIP ![]() 93 KA8 GBP LS 6spd 2005-2008 RIP FOR SALE:dotORG + I<3myLegend(KA/KB) stickers! +more |
it's either type 1 brackets and rotors or type 2 brackets and rotors.
when you buy online i bet it asks coupe or sedan if you enter a year 93 and up. also if you put it as a GS it will list the type 2 rotors. that's if the parts catalog to site you're using is any good |
#7 |
can you use a type 1 rother with a type 2 caliper and bracket
#8 |
i wouldn't do it, the center line is gonna be off, they might even rub the bracket but i doubt it.
#9 | ||
Type I rotor use Type II caliper with Type I Bracket Type II rotor use Type II caliper with Type II Bracket
#10 |
so where can i get type 2 rotors or what i should put when ordering rotors onine because the ones on the car at the pink n pull are nasty
| Type-II calipers | Legend-Coupe | OEM Parts | 8 | 12-11-2009 11:18 AM |
| FS: Rebuilt Type II Calipers | alittlethin | OEM Parts | 13 | 10-31-2009 06:26 AM |
| compressing type 2 calipers? | hotstartup | 2nd Gen. Legend General Discussion | 16 | 09-23-2009 08:43 AM |
| FS: Type 1 calipers and rotors | Jonslegend | OEM Parts | 0 | 08-11-2009 08:05 PM |
| FS: Front Type I calipers | Russian | OEM Parts | 3 | 07-09-2009 12:14 PM |
