#1 |
My clutch pedal feels normal, but it didn't disengage when pushed all the way to the floor today.
I had a complete clutch job done about a month ago (including MC and SC). Today was rather hot and I drove around town for a while before this happened. I let the car cool down for a couple hours, and now it seems to work OK, but I'm reluctant to drive far. The shop put in a clutch kit so hopefully the mechanical parts are all good...maybe it just needs to be bled again? I'm on temp military duty away from home, so I don't have the tools to do much work myself.
1988 Legend LS Sedan Stock Everything (except stereo). |
#2 |
It does sound like you have air in the system. I would re-bleed the system.
My Build Thread Oh my gawd That jar better blow me twice and cook breakfast for $1000. |
#3 |
They bled it, said no air came out. they couldn't duplicate the problem.
Today after it was warmed up I held the clutch in for a minute or so, and then I could feel it turning the input shaft with the clutch disengaged. Now I'm sure it's the input shaft dragging. Might have been caused the first time by me holding the clutch in while waiting for my garage door to open? Looking in the shop manual (OEM) I can't see a needle bearing or bushing... there has to be one on the input shaft, right?
#4 |
What kind of fluid did they put in for the clutch reservoir? And is the fluid in the tranny at the right level?
#5 |
Weeeeell...I ASSUME they used DOT 3. They seem fairly reputable, I doubt they would put DOT 5 in a 1988.
It doesn't leak, and I filled the tranny less than a year ago. Should I check that again? Does tranny oil lube the input shaft at the flywheel? Thks
1988 Legend LS Sedan Stock Everything (except stereo). Last edited by merlinj79; 03-20-2012 at 05:22 PM. |
#6 | |
#7 | |
a lot better than engine oil. |
#8 |
Oh. Does the input shaft just ride in the flywheel hole? How is it lubricated?
#9 |
#10 | |
Could this be a bad clutch disc, maybe dragging on the input shaft? Not sure how it could do that with the pedal all the way on the floor.
1988 Legend LS Sedan Stock Everything (except stereo). Last edited by merlinj79; 03-24-2012 at 01:29 PM. |
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| How hot is it where you are??!?! | Aking | The Water Cooler | 47 | 07-21-2011 09:35 PM |
| Removing Clutch/Swap to 5-Speed Clutch | brettallen59 | 2nd Gen. Legend General Discussion | 1 | 01-10-2011 08:55 AM |
| How hot does...... | XxWEISERxX | 2nd Gen. Legend General Discussion | 17 | 07-07-2010 07:19 PM |
| Fired for being Hot? | cakes | The Water Cooler | 47 | 06-11-2010 06:07 AM |
| This is one hot G1.... | IGotALemon | The Water Cooler | 15 | 08-29-2009 09:55 AM |
